Re-locating O2 Sensor
Old Oct 10, 2010 | 11:37 AM
maachan513's Avatar
Default Re-locating O2 Sensor
A month or two ago I replaced exhaust system with ebay special headers and pipes down stream. I don't know proper words for it. Reused item is the original cat converter. It was less expensive to go this route than go with OE style down pipe and I wanted to try headers of any kind anyways. On this header, the O2 sensor bung is located on #3 pipe and another one located near the cat.
At this time, the sensor is installed on #3 pipe, taking reading from this cylinder only. The engine has 244k miles and lately #3 is showing less compression than the rest. The sensor is on somewhat less efficient cylinder, it may be adjusting F/A ratio wrongly because of that. OE header (cast iron) has sensor port on the section where all 4 ex gas mix.
I have started thinking last week that what would happen to engine operation, fuel economy and such, if I moved the sensor to mount onto another bung where all of ex gas go through.
I wonder if anyone can give me some idea on this.
Old Oct 10, 2010 | 11:44 AM
hondadude's Avatar
The original location was on the Exhaust manifold, so I would say to put the sensor back to that location if there is a bung in that "special header".
You will get the correct reading the system was set up for at that point.
Old Oct 10, 2010 | 12:59 PM
maachan513's Avatar
Physically the location of the sensor on the header is where OE exhaust manifold had it. The header goes from 4 into 2 at the front of the engine and then 2 into 1 near the cat. Bung is located before the first collector.
I did the oil change just now and pulled the spark plugs, too. #3 is sooty and the rest is looking good. I will do compression check now.
(5 minutes later)
I did the compression check and this is what I got. #1= 165, #2= 166, #3=90 amd #4=167. And I was wrong about the bung location. It is located on #2 cylinder.
So, I think I will keep the sonsor at this location (#2) for now.
Thank you for time.
Old Oct 10, 2010 | 03:07 PM
Do the compression test again just incase something strange happened.
Then pour a spoonful of oil into #3 & test again. If it goes way up, it's rings. If it goes up only a little, it's valves.
Old Oct 10, 2010 | 03:52 PM
maachan513's Avatar
The last time I did compression check was on June 10 this year. I did it cold. And the numbers were, #1=160, #2=158, #3=90 and #4=160. I put in "Engine Restorer" additive and the vibration I was feeling got better somewhat. Didn't do oil thing the last time because I was fearing it will be the rings/cylinder that need mechanical attention.
This time, after I posted those numbers, I did oil check and the number went up from 90 to like 135. This kind of seals the deal that the cylinder has major issue in ring/barrel department.
What do you think?
Thanks
ZackNY
Apr 24, 2013 03:26 PM
darkgreen18290
Dec 29, 2012 11:42 AM
heiner921
Aug 24, 2010 08:38 PM
efster420
Feb 13, 2010 01:04 PM
