Rear Brake lights keep going out.
Old Jan 16, 2012 | 12:37 PM
ChicagoBob123's Avatar
Default Rear Brake lights keep going out.
Actucally I have two problems. The lights seem to get water in lenses and the brake lights keep going out on the pasenger side. If I jiggle the wiring it works for a while. What do you do to fix something like this? I never had a car do this ever. Why is it happening. I have replaced bulbs etc.
Old Jan 16, 2012 | 01:13 PM
The year and model would help.
Old Jan 16, 2012 | 06:42 PM
I think Bob has a 4th gen???? Been a while since I remember seeing him.
Anyway, most of the time this is due to the "tail light gasket" leaking. Suggest replacing or trying to "re-seal" as soon as you can. Water and the brake sensor will drive you crazy.........
Old Jan 17, 2012 | 08:57 AM
Sorry for not including the info. I have a 93 Accord DX.
203,950 miles and Going Strong!
Bob
Old Jan 17, 2012 | 01:13 PM
hondadude's Avatar
Way back in my 'used car dept.' days I used a 1/16 drill bit and put a couple drain holes in the bottoms of the lenses. Just don't push hard on the drill bit !!
Having to wiggle wires to get the lights working could mean corrosion in the connectors. It might be worth the time to get the harness parts to the bulb connections from a salvage yard and solder/shrink tube the salvage wires into the harness
Old Jan 17, 2012 | 06:20 PM
Bob
Wow, I actually got the gen right.....
Old Mar 24, 2012 | 06:33 PM
well I think I fixed this. There is a little board with 3 or 4 coils on it. It looks like the one of the connections to the board had a bad solder joint. I reheated it and added some fresh solder and it started working again. Only thing is cause? I think the lens leaks water and is shorted. It gets foggy inside. Is this normal for Accords with some age? Do the tail lights take in water?
Old Mar 25, 2012 | 06:44 AM
Yes, 3rd and 4th gens had a real issue with this. Hondadude gave a suggestion.
You can also pull the lens and either install a new gasket or use some silicone to reseal it....
alyssapie
Aug 13, 2012 10:58 PM
96cord
Aug 2, 2012 12:10 AM
accordion5050
May 22, 2012 06:16 PM
UAA
Mar 12, 2008 10:31 AM
fabulous010
Mar 9, 2007 04:43 AM
