Rear Brakes?
Old Feb 7, 2009 | 06:27 PM
Honda762
Question Rear Brakes?
I have a 2007 Honda Accord SE 4cyl with 37000 miles on the car. the dealer vis telling me that I only have 3mm left on my back brakes and they need replaced? Are they full of $hit or could this be true? They show that the front brakes are fine, but the back ones need replaced. PLEASE GIVE ME YOUR INPUT! thanks!
Old Feb 8, 2009 | 08:22 AM
I have seen rear pads installed w/ the caliper piston misaligned (must be rotated to correct alignment). A small stud on the pad does not enter the + grooves on the piston. Result is slightly cocked pad which will wear rapidly on one end. You should be able to use a mirror and inspect pads through openings in aluminum wheels. If steel wheels, pull the wheel and inspect pads yourself.
Old Feb 13, 2009 | 09:59 AM
Honda762
Question Hard to replace?
Is it hard to replace my rear brakes or do I just need to pull a couple of bolts and swap out the pads? Can I just leave the brake fluid alone?
Old Feb 13, 2009 | 10:27 AM
Rear brake pistons have to be twisted to retract; can't just press them in with a C-clamp. The handbrake auto-adjust mechanism is inside the caliper. Be careful about the rubber dust boots wrinkling & tearing.
This can be done without draining fluid or bleeding the brakes. But somewhere along here you want to flush fresh fluid thru the brake system anyway (every 2 or 3 years).
I would definitely take this opportunity to clean up the caliper slide pins & generally clean up all that stuff.
Old Feb 13, 2009 | 10:30 AM
jcocker03's Avatar
yeah it should be pretty much that easy, but if you havent done a brake job yet you might want to buy a haynes repair manual-available at autozone for like $10-$20, it will guide you through step by step on anything from a brake job to an engine swap. also, i think the rear calipers have to be twisted to retract them, not just pushed straight in. and you shouldnt have to add any brake fluid unless its already low.
Good Luck
alphaney
Feb 12, 2022 10:14 AM
SC Tiger
Jul 11, 2011 09:15 PM
ZionsWrath
Jan 25, 2009 11:19 PM
Jcaleno
Apr 3, 2007 10:34 PM
thunder_x
Sep 27, 2006 11:00 PM
