Rear door lock Problem 2006 Accord LX
Old Apr 20, 2011 | 06:24 PM
jwestbrook's Avatar
Question Rear door lock Problem 2006 Accord LX
I have a 2006 Accord LX 4 door 4 cyclinder and the left rear door is locked and will not unlock manually or by remote. How can I get the door unlocked/open so I can fix it?
I think the acutator has gone bad.
Any help please
Old Apr 20, 2011 | 07:37 PM
I suspect the lock has jammed in lock position. The actuator will not cause a jam. This requires removal of door panel (difficult w/ door closed) and release of jammed lock.
This happened on earlier model Accords on front door and required drilling a hole in the door frame and lock at a precise position to release. Search youtube for "how to open the door on a honda accord". I don't know for certain this applies to rear door, but it's the best I can offer.
A locksmith may be able to help, if he's faced this problem.
Worth a call to a Honda Shop for some help.
Nasty problem. Let us know how you resolve.
Old Apr 21, 2011 | 05:43 PM
jwestbrook's Avatar
Talking Door is Open
I was able to get the door open. I looked up "how to open the door on a honda accord" and found a video at YouTube - How to open the door on a Honda Accord that won't open. that had some interesting information and then found this information "that kind of problem can often be addressed by simultaneously operating the door key and the lift / lock button simultaneously, several meaningful cycles may be needed. Generally the lift button won't quite operate well enough alone and the key likewise."
I though I'd try cycling the key and the lift/lock at the same time and it worked.
The video above shows how to open the door latch without drilling or tearing the actualor out, maybe this will help someone else.
Thanks,
Old Apr 21, 2011 | 06:52 PM
The door lock may in need of lubrication. You want to fix before you face the same problem again.
jza240sx
Apr 30, 2013 04:14 PM
Doublel
Mar 11, 2013 07:57 AM
djrockewfewtimez986
Jul 6, 2010 05:34 PM
bczupryna
Feb 11, 2006 05:50 AM
