Rear Drivers side Window Regulator (sedan)
Hey guys,
My mother in law is having a problem with her window not moving up and down on her 01 Accord LX Sedan. I took off the door panel and checked the wire all the way to the window motor and it is getting power. I am assuming that the motor/regulator is bad. Her window is all the way up.
The problem I am having is,I can't seem to find any that say they are for the rear driver or passenger side. I can only find for the front. Is this the one I need? or does anyone have a link? The picture shows one for the drivers front.
The Honda part number for the rear left side regulator should be 72751-S84-A01. The motor part number for the rear left side should be 72755-S84-A01.
The regulator and motor are separately replaceable. It's different than the regulator/motor assembly in your attached pic. Google the part numbers for various vendor, etc.
The window regulator and motor may not be bad though. It may be a switch problem. I would briefly apply direct 12v power and ground to the motor to see if it works. Switching positive and ground makes it go up/down.
ed1le
Feb 15, 2013 08:21 PM
Michael Bomes
Sep 9, 2012 03:12 PM
RaysHondaAccord1994with247.000miles
Mar 15, 2012 01:54 PM
soba_03
Jun 23, 2010 02:13 PM
