rear motor mount
Old Sep 1, 2007 | 06:51 AM
Naked TREE 2X4
Default rear motor mount
so the 95 had a motor mount that is hydralically controlled. i think i have a problem with the actuator for it. is anyone familiar with this at all?
Old Sep 1, 2007 | 07:38 AM
Default RE: rear motor mount
There is a solenoid valve that supplies vacuum to the motor mount at idle to improve dampening. The vacuum switches an internal valve to enable additional dampening. First check that vacuum is available at idle. If not, check the solenoid valve for function and vacuum supply to the solenoid valve. You can manually apply vacuum and see the vacuum actuator on the motor mount move to confirm motor mount vacuum actuator is working. The rubber mounting of the motor mount can be damaged. This is difficult to access and inspect. Car may need to be raised to see the mount clearly, although it can be seen behind the engine.
baer77
Feb 27, 2009 03:47 PM
kirakitty
Jan 19, 2008 07:17 PM
bedwards97
Mar 14, 2007 03:51 PM
trvlnut
Oct 30, 2006 02:16 AM
Markus26
May 17, 2006 09:28 PM
