rear motor mount
Old Aug 7, 2008 | 04:10 PM
falkore24's Avatar
Default RE: rear motor mount
The vac line isn't easy to see unless you are replacing the mount .... if I remember correctly, it was black plastic wrapped around the black sub-frame on mine .... I had the V6, but it's the same idea. Since you plan to make a lot of power with a turbo system, I'd recommend solid mounts. I forgot who makes them, but they ARE available.
Old Feb 8, 2012 | 04:11 PM
Dakota21601's Avatar
I saw the solid mounts on ebay. So u can replace a solenoid mount w a solid one? I was considering this to try to alleviate my mild vibration in gear. If u do, do u have to do anything vacuum wise like plug a port or anything?
Old Feb 8, 2012 | 04:26 PM
crispin's Avatar
I just changed mine to a 5 speed mount - I havent started my car yet to see if there are any problems
Old Feb 8, 2012 | 04:29 PM
Cool. Let me know. How long/hard was it. Seems it wouldnt b too bad.
Old Feb 17, 2012 | 09:23 PM
Any updates on this? Would consider running a solid mount if it works well. If u do that what do u do withthe solenoid and vacuum lines? Do u have to close the vacuum loop to itself or what?
Old Feb 18, 2012 | 04:59 AM
crispin's Avatar
there is a vacuum line from the top rear drivers side of the intake that going to the mount controller, I just plugged that up.
I really do not see how changing the rear mount to a solid one will stop vibrations.
Old Feb 19, 2012 | 09:20 AM
  #17
So is there a good way to isolate whether the solenoid is bad or if it is the mount? Anyone ever just have to change solenoid? Didn't know if that was even an option to buy separate. My 98 2.3 is only at 72k and has done this for prob 20k miles since my grandma had the car. The mount has definitely not been under any extreme loading...lol
Old Feb 19, 2012 | 09:57 AM
  #18
Have a volt meter and a hand held vac pump?
Old Feb 20, 2012 | 06:58 AM
  #19
Yes to volt meter. No to vacuum pump.
Old Feb 20, 2012 | 03:48 PM
  #20
But might b able to get my hands on a pump easy
