Rear Window break light
Old Nov 24, 2011 | 02:07 PM
Jcaleno's Avatar
Default Rear Window break light
There are about 3 bugs dead and trapped back there, the light works, but i wanna get the whole thing cleaned up, its pretty dusty there too. How do i get to it so i can clean it the entire compartment?
Old Nov 26, 2011 | 07:09 AM
I think from inside the trunck there are like two screws you can remove.
Old Nov 16, 2012 | 02:44 PM
65comet's Avatar
Having a bee, wasp and 4 dead flies in my 93 third brake light, I did some serious searching on how to get it apart. The brake light cover has two threaded studs that come down into the trunk through the window deck and are attached with nuts. But after you take the nuts off, there are still several plastic clips that hold it down. If you try and pry it off you will most likely break the clips (that are almost impossible to find replacements) and put serious gouges in the deck at the pry points. So it is suggested you remove the entire deck. You have to remove the speakers, trim pieces that go up the sides of the window, and there was some vague reference to connections along where the top of the back seat contact with the deck. Since my verticle trim is already cracked, I didn't want to go all the way with that scenario and risk breaking them entirely apart. So I'm going to try placing a vacuum nozzle at one side of the light at the window and blow compressed air in at the other side to see if that will get them out. The window there is also extremely dirty. So I'm going to try taking a micro-fiber cloth and use a sawing motion to draw it down across both sides of the light cover and see if that can get some of the dirt off the window.
Alexss
Jan 20, 2013 06:55 PM
jbl2bgone
Oct 9, 2007 10:19 AM
foxracing31702
Apr 14, 2007 01:07 PM
bigheadballer
Aug 27, 2005 08:16 PM
bigheadballer
