Rear window tint removal.. Will it damage defroster?
Old Jul 25, 2016 | 07:32 PM
cosmosis's Avatar
Default Rear window tint removal.. Will it damage defroster?
I recently bought a 2010 accord coupe. The windows are already tinted, and they look fine except the rear window- this tint is extremely dark and blurry and difficult to see through at night on rear window ..I want to remove it, but places I have called say that they are worried about damaging the defroster lines, and will charge a minimum of $100. I have read about ways to remove the tint yourself, such as ammonia, and heat gun.. Any suggestions?
Old Jul 25, 2016 | 09:47 PM
woody31's Avatar
Almost A Senior Member
Heat gun works,,but as you stated..if you rip one of those lines in the defroster ,,it will not work right,,I have the same issue with my 96,,dreading it,,I may just replace the rear window,,cost vs, damage ?? Take your time,,spray it down with soapy water,,cover the inside of the rear window with a heavy duty bvlack trash bag,,tape it up in place,,park it in the sun for a few hours to help loosen the glue,,,use Goo Be Gone on residue,,good luck.
Old Jul 25, 2016 | 10:34 PM
cosmosis's Avatar
Thanks. Yeah.. Living in the Midwest, can't afford to be without rear defroster. I just wonder if this defroster issue is less likely to happen to a Honda as opposed to, say, a Ford or Kia... Or if all glass with defrosters are built the same...
Old Jul 25, 2016 | 10:59 PM
I used a steamer to remove the tint from my brother's grand prix. You want to make sure you get the tint hot, but not the defroster. Pulled the tint slowly on the back window to remove it and kept an eye on the defroster.
Old Jul 25, 2016 | 11:35 PM
woody31's Avatar
Old Jul 27, 2016 | 01:53 AM
JarvisW's Avatar
Yeah, go slow. and there are kits to fix the elements if you fail.
Good luck!
cyclops2
Apr 5, 2014 11:24 AM
mbaik
May 4, 2010 09:40 PM
2006accordexl-passmirrorbroken
Apr 12, 2010 03:01 PM
expertrifleman238
Dec 18, 2009 07:04 AM
badxdawgx818
Jul 11, 2007 04:32 PM
