rebuild of my engine
Old Feb 25, 2010 | 03:52 PM
kid the killa's Avatar
Default rebuild of my engine
alright, this is kinda a 2 parter lol, i have a 2001 accord with a 2.3 F23a4 vtec, i need a DIY on how to pull the engine out of the car, if that makes sence, ive done it on other cars just not a honda, so i dont wana mess anything up in the prosess, and then also ive got a new block for it and a gasket kit for the engine, and i need to know pretty much how to break it down, the order of the head bolts and everything, if u guys could give me this info it would be very, very appreciated lol
Old Feb 25, 2010 | 04:36 PM
Consider getting yourself a good shop manual, from www dot helminc dot com.
That'll give you everything, including the machining specs for the block & head so you can check out that block.
Old Feb 25, 2010 | 05:26 PM
thanks for the help jim im sure this will make things go alot smoother lol
Old Feb 25, 2010 | 08:08 PM
I had one of those books for 98/99 (when I owned that car) and it's got all the detail. It's the factory shop manual.
Not only what you asked for, but it's got bolting sequences for the cam bearing caps, sequences for the engine mounts (so it doesn't vibrate when you put it back in, all kinds of stuff that you don't know to ask yet.
For a job that big (remove & rebuild engine) it's really worth it. No comparison with the cheap wannabes Chilton & Haynes.
classicdawg27
Jan 19, 2014 03:08 PM
knadd
Mar 30, 2009 09:02 AM
thunder_x
Jul 30, 2007 12:11 AM
thunder_x
May 30, 2007 04:21 PM
RSM93HONDA
Apr 14, 2007 11:13 PM
