Remote key not working
Old Apr 11, 2014 | 03:17 PM
Rilex's Avatar
Default Remote key not working
hello to you all, I am using accord 98, auto transmission, 4cylinders, for some time now my remote key is not working. On pressing it once or twice none of the car doors will open, although it started gradually now is worst. Secondly the AC condenser is leaking at the upper end. Please your help is needed. THANKS
Old Apr 11, 2014 | 04:07 PM
AC condensor has a leak and must be replaced. This requires discharging system, replacing condensor and receiver/drier, adding a bit of lubricant (PAG) to new receiver/drier, and recharging.
Key may require only a new internal battery, or key circuit board can be damaged (too many cycles of press/release!).
New key from Honda or a locksmith is likely needed. You might check ebay to see if you can buy a replacement key w/ programming instructions. Here's one example:
2 New Replacement Keyless Entry Remote Key Fob Clicker Transmitter for KOBUTAH2T | eBay
Old Apr 11, 2014 | 11:27 PM
Rilex's Avatar
thanks to you i will work on the remote and change the AC condensor completely
Old Apr 12, 2014 | 09:04 AM
Recharging requires both vacuum drying and addition of R134a to have best chance of long term cooling.
dannyrl
Sep 30, 2015 04:32 PM
csh217
Jun 17, 2014 05:53 PM
cyberthon
Jul 25, 2013 03:19 PM
01AccordCoupe
Dec 11, 2007 10:32 AM
