Removal of 03 Accord Tail Lights
Old May 8, 2007 | 07:19 PM
ExoXo
Default Removal of 03 Accord Tail Lights
Hello,
I need help with removing my two tail lights on my 2003 Honda Accord Coupe V6. Is there a diagram or something visual that explains how to do it or just anything that can help me out would be great!
thnx
Old May 8, 2007 | 09:41 PM
Fenix's Avatar
Default RE: Removal of 03 Accord Tail Lights
For the most part its simple. Just time consuming. There are several plastic rivits on the underside and in the well where the trunk closes. They can be removed with a flathead screwdriver. There may be a few hex screws, im not sure because there are on the front bumper. Also check in the wheel well for any screws that may be holding the bumper in place. Then carefully remove by pulling the bumper away from the body. Its held in by clips, so its gonna take a certain amount of tugging. After that peel back the lining of the trunk around the tails. You'll see a few screws, 3 on each side i think. Thats basically it, from memory. dont forget to use the rubber grommits on your new tail lights or youll get water in them. If it doesnt help let me know cause then ill scan the page from the haynes manual. Which i suggest you get, helps more than you'll know.
myfirstisanaccord
Apr 24, 2011 08:25 PM
Will.bartlett
Feb 27, 2010 08:44 PM
accordking
Jun 6, 2009 12:08 AM
bluemagic03
Nov 29, 2008 09:43 PM
Aistisval
May 20, 2007 05:00 PM
