Remove engine control module 2000 honda ex
Old Aug 5, 2012 | 07:32 PM
understand1's Avatar
Default Remove engine control module 2000 honda ex
Does anyone know how to remove the engine control module on a 2000 honda accord ex. Its under the driver side but hard to get to because its by the switch that you pulls the hood. How do you remove these panels.
Thanks
Old Aug 5, 2012 | 07:45 PM
Silver6gen's Avatar
the ECU or PCM is actually under the center of the dash. If you are sitting in the passenger seat its to the left of your left foot. pull the carpet back and you will see it.
Old Aug 5, 2012 | 08:40 PM
Old Aug 6, 2012 | 06:06 PM
Default Pictures Driver side- how do i remove in ex 2000 accord
No it is under the driver side on the 2000 Accrod Ex version. I have attached pictures. The only problems is how do I remove the panel so I can remove the ecu. The orange cords are the engine control module. I took pictures in front so you coud see it is indeed under the driver side dash board.
Thanks
Attached Thumbnails Remove engine control module 2000 honda ex-car3.jpg   Remove engine control module 2000 honda ex-car-4.jpg   Remove engine control module 2000 honda ex-car-1.jpg   Remove engine control module 2000 honda ex-car-2.jpg
Old Aug 6, 2012 | 06:28 PM
Silver6gen's Avatar
that is the OBD II port not the ECU
Old Aug 6, 2012 | 07:05 PM
Silver6gen's Avatar
I've looked in my car and can see this module too. But it is not the ECU / PCM.
Old Aug 7, 2012 | 05:46 PM
What issue are you having?
There are a few "controls" under there but they are not the PCM/ECU.....can't tell from the pick but that "might be" on of the multiplex units on the car.......
Old Sep 16, 2012 | 12:06 PM
This is an older thread; but, just for informational purposes, the unit with the orange port under the driver's side dash is the ABS control unit.
charlieadams
Sep 18, 2012 07:11 PM
jlambo86
Feb 7, 2011 12:20 AM
pcpro215
Nov 16, 2009 03:01 PM
00AccordLX5spd
Apr 14, 2007 03:45 AM
Mike_EX
Jan 28, 2007 12:53 AM
