Removing 03 Rotors
I have an 03 EX V6. I'm trying to replace the brake rotors. Is any unbolting required other than removing the calipar carriers? Are there bolts or screws that hold on the rotors themselves? I tried to remove the fronts last night with no luck. I assume the phillips head screws on the fronts of the rotors were left there from machining? Thanks for the help!
I'm a newbie to this forum, so if my question has already been answered elsewhere, I apologize.
..Alpha
..Alpha
that is correct those screws have to come out. Impact screw driver is a good thing for those - I have already broken 2 SnapOn philips bits on my rear rotors = i hope you buy something that can actually hold an impact.
Remember the harder you hit the better - it's a man's tool [8D]
deserthonda
May 12, 2006 04:06 AM
