removing 5th gen turn signal
I just had mine out. On each side of the grillethere isa square cut out.With a flashlight looking through the notchyousee a phillip head screw inside a white plastic housing.
Get on the phillips screw and back it out until it no longer backs out, the screw will remain in the plastic keeper.
Push outward on the light where you removed the screw and it come out. The other side is tabbedso the light housing will roll out on the tabs like a hinge.
