removing 5th gen turn signal
Old Apr 2, 2007 | 05:52 PM
Default removing 5th gen turn signal
I am going to buy the black turn signals off T.A.S. auto, and was wondering how to remove the old ones.
Old Apr 2, 2007 | 05:59 PM
sir_nasty's Avatar
Default RE: removing 5th gen turn signal
this is from a 94 but it should be about the same
[IMG]local://upfiles/3079/14205E6D258D49A0B3F0FF2EF1E5C385.jpg[/IMG]
Old Apr 2, 2007 | 06:09 PM
thanks but those are the corners not the turn signals
Old Apr 2, 2007 | 09:48 PM
2kflhr's Avatar
I just had mine out. On each side of the grillethere isa square cut out.With a flashlight looking through the notchyousee a phillip head screw inside a white plastic housing.
Get on the phillips screw and back it out until it no longer backs out, the screw will remain in the plastic keeper.
Push outward on the light where you removed the screw and it come out. The other side is tabbedso the light housing will roll out on the tabs like a hinge.
Elk Hunter
Oct 2, 2012 11:08 AM
coolcat
Nov 24, 2008 08:39 AM
Ponyboy
Jun 1, 2008 01:13 PM
finch13
Apr 15, 2008 10:13 AM
Cajun
Mar 31, 2008 05:20 PM
