removing antenna
Old Feb 9, 2007 | 10:39 PM
just_me
Default removing antenna
i'm having trouble removing whole unit from the car. i'm following the writeup in the DYI section.
the mast was broken off and has slid all the way down into the "tube" and i cant get it out.
i cant unplug the antenna plug (i think thats what it is) to remove the unit to work on it at my work bench.
edit: this is for a 92 with a power antenna
Old Feb 9, 2007 | 10:52 PM
ArcticHonda's Avatar
Default RE: removing antenna
I take it you have a 90'-97' model accord. The antenna pulg (label "B" in picture) should not give you any trouble coming off...its kind of like an audio jack that just unplugs. Then remove the power connection (label "A"). Then remove bolt ("C"). As long as you have removed the top nut on the outside of your car you should be able to slide the whole unit, antenna and motor, in through your trunk.
[IMG]local://upfiles/6435/435DFDA833004CDBBB93DF2998860A26.jpg[/IMG]
Old Feb 9, 2007 | 10:56 PM
just_me
"B" is what i cant get off.
Old Feb 9, 2007 | 10:58 PM
It may have corossion on it but trust it will come off...just keep working at it. I just did this last week and mine came right off.
Old Feb 9, 2007 | 11:07 PM
just_me
i got it off. it was froze on there with corossion.
Old Feb 11, 2007 | 01:01 AM
fireballer44's Avatar
Just maybe a helpful note if you haven't gotten done yet. I did this same thing on my 91, had a ton of problems. 1st, part of the mast was stuck in the antenna tube (you couldn't see it). So, if your new mast doesn't seem to fit, don't force it. Also, there was a piece of the white plastic cord broken off inside the unit, it would feed but wouldn't fully retract. Just a few experiences of mine I thought could be helpful...
Old Feb 11, 2007 | 04:20 AM
geeaccord's Avatar
Hey that why I never work on a car with out a good can of 10w 40, it's always on in hand.
Eauxkie
Sep 27, 2006 08:18 PM
billyloon
Jul 30, 2006 07:13 PM
msmiz
Dec 22, 2005 09:05 PM
stigedis
Dec 4, 2005 10:12 PM
pgopalak
Dec 17, 2004 03:30 PM
