Replaced ECM - wont start
Old Dec 13, 2011 | 06:57 PM
screamerfreak's Avatar
Default Replaced ECM - wont start
I have purchased this car with ECM issues, or so it seems. i bought a used one based on the matching numbers and plugged it in. For some reason it wont start.
Any ideas??
Old Dec 13, 2011 | 07:00 PM
sorry.. missing info - 2000 accord ex, at , 2dr.
The original ECM had o2 censor codes that would not clear. The shop said it was the ECM.
Old Dec 13, 2011 | 07:07 PM
You have to get the ECM reprogrammed to match your transponder chips in the keys due to the Immobilizer.
Old Dec 13, 2011 | 07:56 PM
Do you know whether your car is an ULEV or non-ULEV? Because, if it is an ULEV and the Air/Fuel Ratio sensor (primary) was replaced with a normal O2 sensor, the code will come back.
Old Dec 14, 2011 | 07:50 AM
Does every 2000 and newer have the Immobilizer system?
Do you know whether your car is an ULEV or non-ULEV? Because, if it is an ULEV and the Air/Fuel Ratio sensor (primary) was replaced with a normal O2 sensor, the code will come back.[/I]
How do you know if it is ULEV or non-ULEV?
Old Dec 14, 2011 | 08:10 AM
accordhybridowner's Avatar
Do you know whether your car is an ULEV or non-ULEV? Because, if it is an ULEV and the Air/Fuel Ratio sensor (primary) was replaced with a normal O2 sensor, the code will come back.[/i]
I'm not sure if it is mentioned in the manual. For my 05 accord hybrid, there is a "ULEV" sticker on the rear left passenger window. Maybe yours has one as well?
Old Dec 14, 2011 | 08:15 AM
In the U.S., 1998 and up Accords have Immobilizer systems. This link has some info. regarding the Immobilizer for your car.
http://www.tegger.com/hondafaq/tsb/accord/x97-058e.pdf
As long as your engine has not been swapped or the valve cover swapped, it should says ULEV on the valve cover. There may be other stickers or tags in the engine compartment that says ULEV. Additionally, the OBD II trouble code that came up for the sensors can help differentiate whether it may be a ULEV or non-ULEV, as the trouble code for an Air/Fuel Ratio sensor (ULEV primary sensor) is different than for a normal O2 sensor (non-ULEV primary sensor).
Old Dec 15, 2011 | 08:04 AM
Thanks for the help!
Jace N Smith
Sep 28, 2013 10:28 AM
mattmackay
Aug 23, 2011 05:52 PM
mattmackay
Aug 20, 2011 02:19 PM
chevmechanic
Apr 20, 2011 06:37 PM
jastunna1987
Dec 22, 2007 04:15 PM
