Replacement of 1995 Accord EX 2.7L V6 Radiator
Old Feb 20, 2010 | 06:19 PM
bauer007's Avatar
Default Replacement of 1995 Accord EX 2.7L V6 Radiator
Bad day! I got to work and discovered a 6" crack in the top of the radiator. I will be replacing it tomorrow. I know the top brackets come off, disconnect the upper and lower hoses, disconnect the 2 fans and remove them from the radiator once it's out and reinstall on the new one. My question: Is there anything else that needs disconnecting/unplugging and do you have any tips for the job. Thanks for your help. I appreciate it.
Old Feb 20, 2010 | 09:35 PM
There are also two lines from the transmission that connect to the bottom that cool the trans. fluid. Disconnect them.
When refilling remember to bleed out the air from the valve on top of the thermostat housing.
lesson1
Aug 8, 2014 09:45 AM
BigRoach
Jun 3, 2013 01:54 PM
Novaknowledgenow
May 30, 2013 08:58 PM
hmr
Mar 28, 2012 10:49 PM
mrbostn
May 18, 2011 09:53 PM
