Vacuum Motor Mount
Old Feb 20, 2010 | 08:01 PM
bruggles1's Avatar
Default Vacuum Motor Mount
Okay, so my car vibrates when in drive and idling. I was told this could be caused by a non-functioning vacuum motor mount system. I unplugged the solenoid when the car was warmed up, and in drive (someone held the brake) and there was no change in vibration. How can I tell if the problem is with the mount or the solenoid?
Old Feb 21, 2010 | 12:49 AM
finch13's Avatar
Connect a vacuum pump to the mount and apply 230 mmHg of vacuum. The valve on the mount should move 80 degrees.
On the solenoid, check for continuity with a multimeter. Also, apply 12v power to it with test leads and see if it actuates.
HwyPilot
Mar 24, 2015 12:24 PM
and4rik
Apr 28, 2010 06:58 AM
baer77
Feb 27, 2009 03:47 PM
Yangster
Sep 5, 2006 08:28 PM
Markus26
May 17, 2006 09:28 PM
