Replacement EGR plugs?
Old Apr 5, 2012 | 08:38 AM
pancho88's Avatar
Default Replacement EGR plugs?
Hey guys, does anyone know where to get the replacement brass plugs for the EGR passages on the 2.2 non vtec sohc? Getting an EGR code so I have to drill them out and clean the passages so they will need to be replaced with new plugs. I called several dealerships and no one seems to know anything about them. Should I go to a hardware store? If anyone has dimensions that would help tremendously. Thanks for any help.
Old Apr 5, 2012 | 11:47 AM
Put your car info in your signature line. Plugs are only used on 90-93 Accords, and I think mostly in 90-91 models at that. If you're 94 or later there are no plugs, just a manifold to remove/clean.
If you have plugs, you can reuse them by potting the holes w/ J&B weld epoxy. That's what I did on my 90 Accord and it worked well.
Old Apr 6, 2012 | 04:12 PM
See if this PN works 17199-PT3-AHM
EDIT: Ok, I'll give up the source....google "T2T013"
ronjr8102
Apr 12, 2011 08:53 PM
olgirlkeepsrunnin
Jan 31, 2010 02:37 PM
RJLhonda
Sep 9, 2008 01:05 AM
oma93
Mar 9, 2008 01:48 AM
AccordEX
Mar 30, 2007 09:49 PM
