aluminum AC lines
Old Apr 6, 2012 | 08:19 AM
northwoods's Avatar
Default aluminum AC lines
Gents:
I am replacing the aluminum AC lines in my 92 EX, but can't bring myself to pay the dealership prices. Anyone have a source for bulk alum tube and fittings, or aftermarket lines at a fair price?
Thanks
Old Apr 6, 2012 | 08:32 AM
crispin's Avatar
I would like to know the same thing
Old Apr 6, 2012 | 12:00 PM
Those a/c lines are probably dealership only parts.
What is wrong with your a/c lines?
Old Apr 6, 2012 | 02:29 PM
northwoods's Avatar
broken
Old Apr 6, 2012 | 02:37 PM
crispin's Avatar
While removing my engine and trans I bent the low pressure line bad enough that it got a leak where it connects to the compressor and all the freon came out.
Old Apr 6, 2012 | 04:09 PM
This is one of those parts that I would get from a junkyard. Those lines seem to last a long time unless you get into an accident.
Old Apr 6, 2012 | 04:44 PM
crispin's Avatar
I need to get my A/C going again asap.
Old Apr 6, 2012 | 05:29 PM
Then I would go to the U-Pull-It yard to get the lines.
I would suggest doing the repair right the first time. IMO, that would involve replacing all of the o-rings in the system. Even the ones under the dash. I would replace the styrofoam in the evaporator. Definitely replace the receiver/drier.
You will probably want to inspect the compressor. If there is a coating of grease around the pulley bolt, then you would want to replace the shaft seal. I also replaced the o-rings in the body when I did mine.
TexasHonda can give you some pointers. He has done some a/c work. I did the a/c on my 95 and it ended up working well after the repair.
Old Apr 6, 2012 | 05:53 PM
crispin's Avatar
I will start a thread on this in the near future so I can learn how to do it all correctly.
OLDERTUNER94
Aug 13, 2012 06:30 PM
FREQUENCY 24.7
Jul 5, 2008 08:17 PM
FREQUENCY 24.7
Jun 2, 2008 09:51 PM
daddy
Apr 13, 2007 03:04 AM
thunder_x
Mar 10, 2007 05:45 PM
