Replacing Gage lights
Old Nov 14, 2007 | 05:52 AM
Dshow's Avatar
Default Replacing Gage lights
Hi, I have a '94 Accord LX 4 dr Auto. I need to replace a couple of gage lights on the instrument panel. I have the manual and this does not look that difficult to do except at the beginning of that section it has a warning about before disconnecting any part of the SRS harness, connect the shorting plugs. I wasn't planning on messing with the SRS system, but I know the dash has an SRS indicator... Do I need this shorting plug just to replace some bulbs? (I don't want an airbag in my face... )
Thanks- Dan
Old Nov 14, 2007 | 09:41 AM
nafango2's Avatar
Default RE: Replacing Gage lights
All the SRS plugs should be shrouded in yellow... just avoid them and you should be fine.
Old Nov 14, 2007 | 04:24 PM
Dshow's Avatar
That's what I thought. Thanks.
Old Nov 14, 2007 | 05:57 PM
I think that diasbling the driver's side might be a good idea since you will be working over the steering wheel. Accidental deployment of the air bag can be fatal. If you are going to be near the pass. side, I would do that one too.
Its pretty simple to do, takes no time at all, and its better to be safe than sorry.
Old Nov 14, 2007 | 06:16 PM
Dshow's Avatar
How do you do it and where does the shorting plug go?
hondaisreal
Nov 27, 2012 08:46 PM
kacies
Jan 10, 2012 09:13 PM
Kimmarlow1
Jun 30, 2011 12:15 PM
La Voce
May 7, 2009 08:27 AM
edy7982
Jun 11, 2007 03:31 PM
