Replacing Inner Tie Rods
Old Jan 26, 2016 | 02:45 PM
cukaracha's Avatar
Default Replacing Inner Tie Rods
Hi guys,
I need to replace the inner tie rods on my '94 Accord LX MT. I did some reading and have a few questions:
1) How difficult is it to un-bend the lock washers? I have a ~10" chisel I could use and a hammer.
2) Will the Inner Tie Rod tool from Autozone work? ie. Is it long enough and does it have a 17mm attachment?
3) What is the best way to bend the new lock washer in place?
4) Any particular complications I should be aware of or take note of before I attempt the repair?
Thanks!!
Old Jan 26, 2016 | 06:59 PM
Have you tested and determined inner BJ is loose? Unusual for them to go bad.
My comments are based on replacing inner BJ on Acura MDX but Accord is similar.
1) Washer can be bent w/ pliers or vise grips.
2) It worked for me. It's a very deep socket.
3) Hammer
4) Access to install the boot clamps. I decided to use plastic wire ties, much easier but not as durable. Note to self to check how they are holding up!
Old Jan 26, 2016 | 07:43 PM
cukaracha's Avatar
Thanks for the reply.
When I turn the steering wheel to almost an extreme, I can here a clicking/grinding noise coming primarily from the driver's side. Also, there is vibration in the steering wheel at highway speeds.
I've already replaced the lower ball joints, upper control arms, and outer tie rods on both sides. The driver-side axle has also been replaced last year and the passenger-side axle boot isn't torn or worn-looking. Furthermore, the inner tie rod boots are severely torn on both sides.
Just to be sure, is it safe to assume that my diagnosis is accurate?
Old Jan 27, 2016 | 01:30 PM
With the wheel elevated and removed, push/pull the wheel/knuckle to force the steering. If inner BJ is loose you will be able to see movement of tierod w/o corresponding steering column or steering wheel movement.
Another way would be to have a helper turn steering wheel while observing tierod. There will be steering wheel movement w/o corresponding tierod movement.
In my MDX case, I felt a "popping vibration" on tierod when turning steering wheel slightly. I thought inner BJ was binding/reieasing to cause the vibration. When I opened up I found inner BJ was good, but replaced it anyway. Vibration was finally determined to be from CV axle. Axle boot was fine but it had internal wear causing the popping.
Redskin63
Sep 23, 2015 05:35 PM
slickgeek
Nov 6, 2014 02:01 PM
jerrym
Apr 9, 2010 12:05 AM
riverman
Mar 27, 2010 07:41 PM
thunder_x
Oct 31, 2007 07:34 AM
