Starting Problem
Old Jan 24, 2016 | 09:46 AM
Jones264's Avatar
Default Starting Problem
I have a 98 Accord 4cyl non vtec. It will start and run fine when its cold, but when its warm it will just crank. I know it has a spark and fuel because i replaced the coil, distributor, fuel pump, fuel filter. Please help
Old Jan 24, 2016 | 11:01 AM
Diagnose before throwing parts at the problem.
Have you checked for engine codes?
When the car is not starting, turn the key to the II position, but do not try to start the car. Do you hear the fuel pump turn on for about two seconds when the check engine light does the bulb check? It is a faint buzzing/whirling sound that comes from the back seat, so turn off the radio, blower, etc and listen carefully.
Old Jan 24, 2016 | 12:53 PM
Jones264's Avatar
The check engine light was on and it gave me a code for the front temperature sensor. Replaced it and check engine light went off and same problem. I do hear the fuel pump when I turn the key to the "on" position
Old Jan 25, 2016 | 11:36 AM
Try spraying starter fluid & see whether it fires up for a second or 2. That can point either to lack of fuel vs. lack of spark.
I know you said you have fuel & spark, because you replaced all that stuff. Even though you hear the fuel pump running, that doesn't prove the injectors are actually firing and delivering fuel into the engine.
You need Air, Fuel, Compression & Spark. Air & compression are almost always OK especially because it'll start when it's cold.
Old Jan 25, 2016 | 12:11 PM
Jones264's Avatar
Will not start with the starter fluid when its warm. I forgot to mention that after it runs and sits for a few hours it will start but struggle to do so. It chugs around 200rpm for a few seconds and I have to pump the throttle. It kinda sounds like a flooded carb when it starts if that makes sense
Old Jan 27, 2016 | 08:43 AM
Dr. Drivability's Avatar
Still haven't verified whether or not you actually HAVE spark when the problem is occurring. You need to check if you have power to the distributor.
Old Jan 27, 2016 | 09:17 PM
Spark is easier to verify compared to fuel. If you have a spark tester, connect it, then see if you have a spark when the car is not starting. A timing light is another way to check for spark, if the light flashes when you try to start the car. If spark is missing, you can work backwards.
Yamasaki
Nov 5, 2011 09:19 AM
quack31
Feb 5, 2007 05:07 AM
cyurgeles
Jan 21, 2006 10:36 AM
rev2ninetyper
Nov 14, 2005 04:06 PM
karmajay
Sep 13, 2005 06:57 PM
