Resetting the idiot light..
Old Apr 10, 2009 | 01:01 AM
mirgladd
Default Resetting the idiot light..
Please forgive me if this has already been asked. I looked through the forum & didn't see it. I have an 07 Accord EX-L. We've had it since December, & my husband changed my oil about a month ago before he deployed. It was at roughly 15% oil life then. He couldn't figure out how to reset it, so we figured maybe it would reset itself, maybe it had a sensor or something. A month later it still hasn't reset itself. It's now showing -1 & 300-something whenever I crank it up. I'm wondering if I'm going to have to take it back to the dealership & have them reset it, or if I'm just completely lost & it's something simple that I haven't noticed yet.
Old Apr 10, 2009 | 02:00 AM
I don't know how to reset it on your car, but I am sure that information is in the owners manual.
Old Apr 10, 2009 | 06:39 PM
mirgladd
I didn't see anything about it in the manual, but I'll look through it again to be sure. Thanks.
Old Apr 10, 2009 | 08:41 PM
pcpro215's Avatar
If you mean the check engine light, a really simple way to resest is to pull the neg. battery cable, leave it off for about a minute (need to clear the computer) and install the cable. That should clear it for you!
Old Apr 10, 2009 | 09:01 PM
crvone's Avatar
Hi Mirgladd,
Try reseting the maintenance minder as follows:
Turn the ignition switch to the ON (II) position.
Press the Select/Reset knobrepeatedly until the engine oil lifeis displayed.
Press the Select/Reset **** forabout 10 seconds. The informationdisplay shows the resetmode
initial display (as shown in manual).
Select the ‘‘OIL LIFE’’ indicator by turning the Select/Reset ****.
The display begins to blink. Push the same **** to enter this setting.
The engine oil life and the maintenance item code(s) will begin to blink.
Push the Select/Reset **** and hold to reset. (make sure to hold)
The maintenance item code(s) will disappear, and the engine oil life will reset to ‘‘100.’’
Old Apr 13, 2009 | 07:53 AM
That oil-life display does NOT actually measure anything about the oil, it just keeps track of time & miles & temperature & a bunch of other stuff. The display was at 15% when the oil was changed, but it wasn't reset. You have used 15% or 20% of the new oil, & NOW you reset the counter.
Since the new oil was already down to 85% or 80% before you reset the oil-life, next time you should change the oil when it gets down to 20% or 30%, don't wait for the warning light to come on. Then reset the oil-life when you change it.
Mott
Mar 15, 2016 11:25 AM
matnik84
Apr 11, 2011 06:01 PM
renegade05
Aug 10, 2010 10:43 PM
99HondaAccord
Mar 31, 2009 10:36 AM
razcob
Dec 22, 2007 06:12 PM
