Rough idle after warm
Old Apr 7, 2012 | 11:40 PM
  #21
The EGR valve is vacuum controlled. The ECU sends a signal to the EGR control solenoid valve that lifts the EGR valve to a certain position. The EGR control solenoid has its vacuum regulated by the vacuum control solenoid.
A code 12 is set when the lift sensor in the EGR valve does not reach the height when the ECU opened the control solenoid valve. The problem can be the EGR valve, the vacuum hoses, the EGR control solenoid, the EGR vacuum control solenoid, the ECU, or the wiring.
If you look in that shop manual, page 11-115 starts the diagnosis for a code 12. You should try to go through those steps to see what is going on.
BlackLX4
May 30, 2015 10:01 AM
cascius
Aug 30, 2013 07:57 AM
Ricksaneejit
Jun 3, 2012 12:38 PM
sis00accord
Dec 19, 2011 12:27 AM
raleighfirewall
Mar 16, 2007 08:33 AM
