rough idle & sputtering
Old Jun 5, 2012 | 10:44 AM
mcristo's Avatar
Default rough idle & sputtering
Hey what's up. I have a 94 Accord LX 5sp. It has 214k miles. It just started to have a rough idle and I can feel it sputter while driving. It does not stall. It just passed smog test with very good numbers. Before the smog I did a tune up and noticed oil on the spark plugs. I know I need to change the valve cover gasket and grommets, could the oil on the plugs be the cause?
Thanks, Mike
Old Jun 5, 2012 | 01:27 PM
Very well could be, you def want to rule that out before chasing anything else....did you replace the cap and rotor when you did the tune up?
Old Jun 5, 2012 | 01:42 PM
mcristo's Avatar
No, but I plan to when I change the valve cover gasket.
Thanks, Mike
Old Jun 6, 2012 | 11:08 AM
mcristo's Avatar
Well, it's fixed. I changed the valve cover gaskets and grommets and when I pulled the spark plugs, the tip was burnt and melted on one of the plugs. (defective plug)? It was an E3 spark plug that I tried. Put back in some NGK's and no problems.
Old Jun 6, 2012 | 08:50 PM
Cool And thank you for coming back with the answer, too many of these end up with no answer.
Old Jun 8, 2012 | 10:57 AM
mcristo's Avatar
Back again. 3 days since I changed to valve cover gaskets and spark plugs and I am getting the sputtering and hesitation while driving. I think the spark plug electrode is going to be melted again. I will pull it after work and follow up. Any Ideas?
Thanks, Mike
Old Jun 9, 2012 | 08:54 PM
Small chance that the oil leak had damaged the insulation on the sparkplug wires. Check for arcing...
- Complete darkness with cold engine (like maybe 3am?)
- Open the hood & turn off all the lights
- Start the engine & look for arcing (or the dull blue glow of a corona discharge)
- Replace whatever is glowing or arcing.
Old Jun 11, 2012 | 09:48 AM
mcristo's Avatar
OK. Did a full tune up on Friday, wires, cap, rotor, and NGK plugs. So far no problems. I think it was all the OEM parts, the cap was cracked, and the rotor screw was almost seized due to rust. Cleaned it all up and installed the new parts. I will let you all know if it happens again.
Thanks, Mike
Old Jun 11, 2012 | 10:45 AM
Distributor cap was cracked?? That'll do it right there.
I would have been tempted to replace the cap & rotor ONLY then see if that fixed it.
Old Jun 14, 2012 | 05:45 PM
mcristo's Avatar
Back again. 3 days after a complete tune up it started misfiring. i pulled the #4 plug to find the gap closed on it. Took it to the shop they said timing was fine and the put a scope down the cyl to check for a foreign object, nothing. Could the piston be coming up and hitting it? from what i heard is that the piston will not travel up that far on these engines. engine sounds fine no knocking or pinging.This plug i just put in i added 2 extra gaskets to see if it helps. not sure what to do next.
Thanks, Mike
