ROUGH SHIFTING
Old Jan 18, 2006 | 11:39 PM
AJ's Avatar
AJ
Default ROUGH SHIFTING
THE GEARS SEEM KIND OF ROUGH WHEN I SHIFT, IS THIS A PROBLEM, OR JUST THE CAR WEARING IN. SHOULD I BE CONCERNED ABOUT IT?
Old Jan 19, 2006 | 01:19 AM
deserthonda's Avatar
Default RE: ROUGH SHIFTING
if your car is 10 years old they are not wearing in,,,,,,,,,if it is 1 year old they are not wearing in,, no such thing... what is the year , model, tranny type?? i am assuming it is a manual ??
Old Jan 19, 2006 | 03:53 AM
lightshow's Avatar
you have the 6spd right? your not driving a camry there, you should slam that bitch into gear.
lightshow
Old Jan 27, 2006 | 07:28 AM
EMEX's Avatar
if you're having trouble shifiting, i'd suggest the first thing you do is check the master and slave cylinder for the clutch for leaks or bleeds. if that's not the problem, then i think it's time for you to change your clutch, flywheel, and bearing
Rotten kid
Apr 21, 2012 08:43 PM
Koss02
Mar 28, 2012 12:47 PM
sa2ms7on
Jun 14, 2011 07:26 PM
donkeydawn11
Mar 30, 2010 06:33 AM
dan
Nov 21, 2006 04:07 AM
