rough shifting in accord 98
Old Sep 13, 2013 | 09:22 AM
Rilex's Avatar
Default rough shifting in accord 98
hi, could it be clogged Injector nozzle causing the erratic hard shift, my mechanics said the auto transmission is perfectly ok and it needs no replacements. Please kindly respond. Hoping to hear from you guys. Thanks
Old Sep 13, 2013 | 01:07 PM
Is Check Engine light on and have you checked for trans codes? Some trans codes don't set D4 light flashing so check for codes.
Has ATF been changed recently w/ new Honda ATF. Aftermarket ATF can affect shift quality.
Old Sep 13, 2013 | 02:28 PM
Rilex's Avatar
the check engine light is flashing now. One mechanic shop scanned and gave the following reading: 7002 A/T SYSTEM MALFUNCTION. Another mechanic shop said there is no problem with the transmission. The transmission fluids have been changed 4 days ago. I have been spending so much on it. What is the exact cause of the hard shift? Is it clogged Injector nozzle or transmission failures. Presently the hard shift is beginning to reduce because the mechanic has been working on it today. Thanks hope to hear from you soon
Old Sep 13, 2013 | 05:29 PM
You must have mis-heard the code. There is no P7002 code. There is a P0702 code for general electrical fault. It means there is a transmission control unit code stored. You can also check these codes yourself by shorting the service check connector under the dash and reading flash codes of CEL or D4 (trans control).
Is D4 light flashing also?
Rotten kid
Apr 21, 2012 08:43 PM
Koss02
Mar 28, 2012 12:47 PM
donkeydawn11
Mar 30, 2010 06:33 AM
dan
Nov 21, 2006 04:07 AM
AJ
Jan 27, 2006 07:28 AM
