RPM's high on 92 accord
Old Apr 5, 2009 | 12:35 PM
larryg
Default RPM's high on 92 accord
Just purchased a 92 accord lx, 4 cyl., auto transmission. At 65 MPH the rpms run at about 2,900 to 3,000? Is this normal for an accord? The car seems to run fine, I just thought it should be closer to 2,100 or so.
Old Apr 5, 2009 | 12:42 PM
This is correct for 90 Accord and probably same for 90-93 models. My 94 runs a bit lower rpm (2600 or so) at 60-65 mph.
Old Apr 5, 2009 | 01:06 PM
larryg
also, the temp gauge runs just above the cold when on the highway and mid range when in town driving. could this be a thermostat problem.. i was thinking of having the cooling system flushed and new thermostat installed if you think this may be an issue.
thanks texashonda!
Old Apr 5, 2009 | 01:44 PM
A new thermostat is indicated. Temp should be same on street or highway. OEM Honda thermostat is best for quick warm up and outstanding temperature control.
brian74d
Jan 28, 2013 03:09 PM
jeffradja
May 1, 2011 07:25 PM
Taintd95EX
Feb 28, 2011 04:55 PM
yamahabalu
Sep 28, 2009 02:11 AM
accord98ex
Mar 18, 2008 09:12 AM
