Rubbing noise left rear '93 accord wagon
Old Sep 16, 2014 | 12:41 PM
Inkyfingers's Avatar
Default Rubbing noise left rear '93 accord wagon
I purchased '93 Accord wagon, the left rear caliper was stuck and made the wheel very hot. I replace the caliper and pads, it makes a rubbing noise, most noticeable when backing up. Also the ABS light comes on soon after you get going. Is the rotor warped?
Old Sep 16, 2014 | 01:49 PM
hondadude's Avatar
If the wheel got hot there is a good chance the rotor warped.
You can roll along slowly, and lightly pull on the parking brake [or lightly step on brakes] to see if it gives a "on/off" feeling.
As far as the rubbing or scraping noise....maybe the brake pad squealer tab is dragging ?
It would be best to jack up that wheel and spin it backwards to find the noise.
Old Sep 18, 2014 | 05:55 PM
Wow...there is someone I haven't seen in a while......"hondadude", I hope things are going ok.
Sorry to the OP, just haven't seen/heard from hondadude in a while.
zedjr
Jan 14, 2013 01:25 PM
elvis1977
Dec 3, 2012 08:08 PM
rjnyc
Feb 21, 2010 07:12 PM
joncnca
Aug 15, 2009 09:12 PM
FlyLow
May 8, 2006 06:00 AM
