s light code flashes 9 times and check engine light flashes 2 times
Old Jan 28, 2008 | 03:33 PM
ddold@gkschools.org's Avatar
Default s light code flashes 9 times and check engine light flashes 2 times
i have a 1990 accord ex 4 door and i checked the code by jumping a wire on connector but i cant find the page that tells what they mean? can you help sir nasty or desert honda thanks dan
Old Jan 28, 2008 | 04:32 PM
sir_nasty's Avatar
Default RE: s light code flashes 9 times and check engine light flashes 2 times
It appears to be either an O2 sensor or the VSS, does your cruise/speedometer work? What's the car doing?
Old Jan 28, 2008 | 04:36 PM
sir_nasty's Avatar
is the code 9 just 9 short flashes repeated?
Old Jan 28, 2008 | 08:58 PM
Code 9 is NC Speed Sensor electrical fault; coupler, wiring, or sensor. This is not the Vehicle Speed Sensor. It may be a similar type of sensor.
Two flashes should be two long flashes for code 20, since there is no Code 2. Code 20 is electronic load detector circuit fault.
Old Jan 29, 2008 | 06:05 AM
the speedo works after replacing gauges cruise works fine.Car runs ok but trans shifts hard and downshifts hard.I don't know if thats related to the lights or not. I think it is 9 short flashes on the S light
Old Jan 29, 2008 | 11:50 AM
The trans code 9 is 9 short flashes on S-light, as explaned above.
Old Jan 29, 2008 | 03:35 PM
On the TCU: 9 is the NC speed sensor. If you go to the DIY section, there is a link for online manuals. You can download a 91 shop manual as a pdf. The electrical test for the sensor is on page 9-40 and the location of the sensor is on 9-23.
recheck the ECU code. In that 91 service manual, there is no code 20.
Mott
Mar 15, 2016 11:25 AM
dlite922
May 3, 2013 06:39 PM
mursheddy
May 7, 2012 12:47 PM
biz_accord
Aug 11, 2010 06:14 PM
ddold@gkschools.org
Feb 14, 2008 03:20 PM
