is it safe to jump my vtec solenoid to the battery?
Old Dec 31, 2011 | 02:08 PM
nunezm08's Avatar
Default is it safe to jump my vtec solenoid to the battery?
95 accord ex 4cyl F-series
I had no vtec, and code 22. I bypassed the oil pressure switch by connecting wires A4 to D6 and the code cleared right up! Still no vtec and now code 21, I jumped the solenoid to the battery and it clicks so good solenoid. Plunger works, and screen not clogged. I checked if any voltage is coming from the ecu to solenoid and no volts. So I'm guessing a short or bad ecu maybe?? I also have my solenoid connected directly to the battery and my vtec is running like a champ, but is it safe? Will my battery drain? Any advice is appreciated.
Old Dec 31, 2011 | 04:51 PM
Get the car back to the stock setup, then start doing the electrical troubleshooting.
Old Dec 31, 2011 | 06:25 PM
joec44's Avatar
Default Vtec
May I add have you checked the oil latley?LOw and dirty oil can cause a lot of problems
Old May 16, 2012 | 10:09 AM
nunezm08's Avatar
Heads up, works like a charm. I have the solenoid straight to the battery on a switch in my car
westcoasthonda
May 25, 2019 06:25 PM
togles
May 9, 2017 07:32 AM
mikek
Oct 8, 2011 11:11 PM
Accord03V6mt
Jul 6, 2010 12:49 PM
RTexasF
Feb 14, 2006 10:45 PM
