Seeing Blue Smoke Come From Exhaust!!
Old Aug 11, 2009 | 11:53 PM
abr0s's Avatar
Exclamation Seeing Blue Smoke Come From Exhaust!!
i just got ma car from changin the clutch slave -n- slave cylinder and for some reason i see blue smoke come from my exhaust and now ma car jus automaticly jus shuts down if i completey stop sooo do i need a oil change or new spark plugs?
Old Aug 12, 2009 | 02:30 AM
You should put the year/model of accord in your signature so we know what year accord you own.
Blue smoke would indicate that you are burning oil. Changing the clutch or slave cylinder shouldn't cause that to happen.
Old Aug 12, 2009 | 01:38 PM
abr0s's Avatar
i have a 92 honda accord ex coupe vtec h22 engine but does that mean i need to change the oil?
_______________
92 Accord Ex H22
Old Aug 12, 2009 | 07:34 PM
I would start with doing some routine maintenance. Change spark plugs, distributor cap, and rotor. Change PCV valve. Change oil and oil filter. Also air filter.
Inspect the spark plug wires for cracks in the insulation.
Clean all ends of both battery cables and make sure that they are secure.
Old Aug 13, 2009 | 11:48 AM
abr0s's Avatar
how much u think valves and rings cost? cause i did take it a shop they said i might need ones sooo im kinda cheap but i need them ill buy them.
technobie
Apr 15, 2013 03:45 PM
fracas
Jan 23, 2013 10:26 AM
bpethomas
Jun 3, 2012 11:10 PM
93AccordEx
Apr 16, 2008 10:10 AM
nrangerfan
May 20, 2005 01:57 AM
