Seeing Blue Smoke Come From Exhaust!!
i just got ma car from changin the clutch slave -n- slave cylinder and for some reason i see blue smoke come from my exhaust and now ma car jus automaticly jus shuts down if i completey stop sooo do i need a oil change or new spark plugs?
You should put the year/model of accord in your signature so we know what year accord you own.
Blue smoke would indicate that you are burning oil. Changing the clutch or slave cylinder shouldn't cause that to happen.
I would start with doing some routine maintenance. Change spark plugs, distributor cap, and rotor. Change PCV valve. Change oil and oil filter. Also air filter.
Inspect the spark plug wires for cracks in the insulation.
Clean all ends of both battery cables and make sure that they are secure.
technobie
Apr 15, 2013 03:45 PM
