Seized sleeve in lower control arm bushing 04 Accord
Old Apr 15, 2018 | 05:06 PM
Jpat1957's Avatar
Default Seized sleeve in lower control arm bushing 04 Accord
My compliance bushing was all shot on passenger side of car . 2004 Accord lx. Changed out bushing and was told should do it in pairs . The car has over 200 on it and other side is crack , but not falling apart as other side was that I replaced . Thing is I got compliance bolt loosen and strutt bolt loose also . But is one long bolt left in control arm which go trough bushing into frame . I broke it free , it might turn 1/8 of a turn then fell resistance and see bushing trying to turn . Used impact and the breaker bar with no luck . Any tips or help would be appreciated.
Old Apr 15, 2018 | 05:43 PM
You may want to use a chisel on the edge of the inner bushing to crack or split the inner bushing. You may be able to free up the inner bushing by doing this as well.
Colondo
Jan 25, 2013 09:58 AM
spudman49
Oct 13, 2008 02:47 PM
mtnbay
Jul 20, 2008 03:22 AM
hkbballboi
May 18, 2007 05:41 PM
