My 2001 Honda Accord starter doesn’t click or engage , Now What?
Old Apr 16, 2018 | 12:24 PM
Shutup's Avatar
Default My 2001 Honda Accord starter doesn’t click or engage , Now What?
It’s not the battery or the imobizer key I checked all that properly , Their was No warning of any problem just turned off car then next time would not turn over , Engine is fine , Now what replace the starter ?
Old Apr 16, 2018 | 01:05 PM
The Toecutter's Avatar
Try jumping the starter big and little terminals, and see if the starter turns over. If it does, then you'll want to check the neutral safety switch, and or the park position switch (you didn't mention if the car is AT or MT).
If the start still fails to turn over, the you need to replace the starter. Use a Denso starter for replacement.
Old Apr 16, 2018 | 03:36 PM
Or try the caveman test. Hit the starter with something (broomstick?) while a helper turns the key to START. If that makes it go, then the problem is the starter itself.
It's a one-sided test. If that doesn't make it start, it doesn't prove anything about the starter itself being good or bad.
Old Apr 16, 2018 | 04:46 PM
irhunter's Avatar
I would suggest, after you've done the above-suggested backyard tests, to pull the starter off and take it to Autozone, or some other place, which will test it, for free.
Just one more step in preventing the buying of unnecessary parts.
Old Apr 16, 2018 | 06:22 PM
Do your brake lights turn on when you press the brake pedal?
2handband
Feb 1, 2018 02:41 PM
cukaracha
Jan 6, 2016 09:03 PM
hon2007
Jul 24, 2012 12:25 PM
rambzy
Dec 3, 2010 11:52 AM
usefullmatter
Apr 21, 2010 06:36 AM
