starter will not engage
Old Feb 1, 2018 | 01:39 PM
2handband's Avatar
Default starter will not engage
Hi... my 91 accord with automatic tranny has a new starter and a new lock cylinder, and the starter signal fuse is good. nevertheless the starter is not engaging when I turn the key. Any ideas what the problem might be?
Old Feb 1, 2018 | 02:41 PM
First, check whether the small wire at the starter actually gets live +12v when you turn the key. Unless the new starter is bad right-out-of-the-box, I bet you don't have a start signal on that wire. Then you start looking at components in-between the key and the starter.
Neutral-safety switch? Do the PRNDL lamps light up correctly?
How about the lock cylinder? That's just the mechanical key & cylinder, right? How do you know the electrical part of the switch is OK?
leescotty2001
Oct 29, 2013 06:50 PM
fjpthree
May 28, 2013 09:36 PM
Rice
Apr 27, 2012 08:38 AM
Jeff Seabarkrob
Dec 29, 2011 10:30 PM
thadjons2007
Nov 19, 2010 06:15 PM
