93 Honda Accord -- can I replace the distributor without setting to TDC and all that?
Old Apr 19, 2018 | 01:47 PM
Orz's Avatar
Orz
Default 93 Honda Accord -- can I replace the distributor without setting to TDC and all that?
I have a 1993 Honda Accord, 2.1L, 5spd manual. The distributor seems to have failed (or rather the ICM inside it, but the rotor seems to be stuck on too solidly to pry off to just replace that part, and there are also signs of general corrosion inside it.).
Can I just put in the new distributor I got without having to follow all the official instructions of setting the cylinders to Top Dead Center and all that stuff? It's broken down in a rather out of the way spot, and I don't have the tools to crank the engine over by hand. Because of the way the distributor slots into the crank, as far as I can tell from looking it over the only thing I can get wrong would be to install it with the rotor turned 180 degrees. Is that right, or is there something else I can break that I'm missing?
Old Apr 19, 2018 | 02:43 PM
You don't have to set the engine to TDC to install the distributor. Just make 100% sure the rotor is pointed in the right direction. I installed a distributor 180 degrees off after I had posted the same advice countless times on this site.
The distributor housing can rotate in the cylinder head to do a fine-tune timing adjustment. You would need a timing light to do this. You can mark the current location of the old distributor and cylinder head to get the new distributor close (see video below).
Old Apr 19, 2018 | 03:24 PM
Orz's Avatar
Orz
Okay. Thanks!
Old Apr 19, 2018 | 05:25 PM
If you mark it & try your best to get the new one close to the proper position, you'll be able to drive home & THEN adjust it properly with a timing light.
Old Apr 20, 2018 | 11:50 AM
The Toecutter's Avatar
Yes, you can install it without having everything to #1. But be especially careful to get the tab/tangs aligned with the slot in the cam. If you get it off, it can break those tabs right off creating a bigger problem.
Also, the rotor probably has a screw holding it in place, which is why it doesn't want to come off.
On my 97, I changed the distributor too, as it had an internal oil seal leak that slimmed everything inside. I didn't reset it to TDC either. I just made sure the tabs aligned with the slot and was good to go. Just be aware of where the old rotor was pointing when you take the old one off, and point the new one in the same place and you should be good.
naterj24
Aug 30, 2016 10:15 PM
Weebiecat
Sep 5, 2013 11:54 AM
deadhonda
Nov 24, 2011 12:55 PM
Slowaccord
Aug 22, 2007 06:37 PM
Philthy
Mar 14, 2007 03:47 PM
