setting ignition timing on 92 accord 5sp man.
Old Sep 17, 2011 | 09:32 PM
crshbandit's Avatar
Default setting ignition timing on 92 accord 5sp man.
I need help on how to set the ignition timing on my 92 accord. I can't seem to locate where the pointer is located on the engine so I can set the timing using my timing light. Thanks for any help.
Old Sep 17, 2011 | 10:14 PM
I think 92 is the older style with a "window" on the bellhousing & markings on the flywheel??
Old Sep 18, 2011 | 07:31 AM
crshbandit's Avatar
Should I be able to see the window when looking down from above the engine? Maybe there is some sort of a plug covering the window? I wish I had a service manual but my library doesn't have one.
Old Sep 18, 2011 | 08:29 AM
In the General Tech section, which is where I moved this, there is a sticky at the top (Common DIY Threads) it has a link to sites you can download one.
Anyway, look below the dist, towards the front of the car, where the engine and trans meet- is there a black rubber plug? I'm with Jim, can't remember.
The pic is for a 91. Also know that the sevice connector needs to be jumped when doing this, if not you will be fighting the ECU.
Attached Thumbnails setting ignition timing on 92 accord 5sp man.-4th-gen-timing.jpg
deadaccord92
Nov 17, 2010 10:05 PM
the_skin_eater
Mar 29, 2009 08:03 PM
kris_loehr
Dec 2, 2008 08:40 PM
Slowaccord
Aug 22, 2007 06:37 PM
Philthy
Mar 14, 2007 03:47 PM
