shaking-pulsating 00 v6 coupe
Old Jul 31, 2006 | 11:56 PM
frankefhm
Default shaking-pulsating 00 v6 coupe
Hello I am fairly new to this forum, I have a slight issue with my 2000 accord v6 ex coupe. I have about 78000 miles and the car runs very well exept for one thing, when crusing @ 45-75mph and the car is in overdrive if I press slightly on the gas the car gives a slight jolt. It feels like the transmission is shaking, and the problem is twice as worse with the a/c on. I have no check lights on, but I am going to get the egr replaced with the upgrade kit (warranty) at the dealer soon, maybe that is the problem. Any one heard of broken tranny mounts? Again, vibration when in overdrive and the accelerator is pressed in slightly. Help please..
Old Aug 1, 2006 | 08:21 AM
YeuEmMaiMai's Avatar
Default RE: shaking-pulsating 00 v6 coupe
trans is toast. Just keep driving it until the problem gets a little worse and then take it to Honda. You can take it now but they might push you off a little until the proble is more noticable. Your car is covered by a 7 year 100K warranty on the transmission
Old Aug 2, 2006 | 01:05 PM
lightshow's Avatar
its just one little jolt? like if you are coasting and then hit the gas a little? that might just be some play in the tranny, but those transmissions do have a bad record
Old Aug 2, 2006 | 03:42 PM
frankefhm
It is a constant shaking, it is not to bad but enough to **** me off. Also it seems to be the worst under stress, like when the car is going up hills with the a/c on. The problem will dissolve when shifted into 3rd gear at the exact same speed.
Old Aug 2, 2006 | 03:45 PM
sir_nasty's Avatar
I would agree.... it sounds tranny related to me... As was stated there is a warranty on it so I would probably at the very least take it to the dealership and show them what's happening if they blow you off that's fine but at least then you can show a track record of trying to resolve the issue... if they fix it then great problem solved.
Deejayphilo
Apr 13, 2012 11:04 AM
d0nd0n
Jan 8, 2012 05:34 AM
babyzone2
Aug 18, 2010 03:56 PM
accord6146
Apr 25, 2007 02:21 PM
vanessa
Jun 5, 2005 11:07 AM
