shift lock?
Old Jan 14, 2006 | 12:50 AM
strictly07
Default shift lock?
Hi noob to the forum.I have a 91 accord auto and when I go to shift from park,instead of stepping on the brake I have to lift on the gas pedal and press the brake.The motor wants to stall when i do this.Any fix to this problem?There is a key hole for the shift lock,how do i disengage the lock?All help app thx Jon[&o]
Old Jan 14, 2006 | 06:54 PM
lightshow's Avatar
Default RE: shift lock?
ill be able to reply to this a little later when i get to work.
lightshow
Old Jan 14, 2006 | 08:56 PM
strictly07
thx
Old Jan 14, 2006 | 09:29 PM
lightshow's Avatar
hey welcome to the forum. glad to have you here.
there is this little rubber boot on your throttle cable that goes out and creates play in the gas pedal. if you take up that slack in the engine compartment this will eliminate that. there are a couple 10mm nuts that hold the throttle cable to the throttle body, loosen them. if you need further help as to where the throttle body is let me know. but tighten up the slack in the cable and your gas pedal wont dangle anymore. as far as the car trying to stall. dont use the cable to increase the idle of the car. if you look into the throttle body hole, on the top of the throttle body there is a flat head screw. turn the screw to the left to imcrease the idle, right when you hear the iac valve start to hiss is the perfect setting. pm me if you need any more detailed info.
lightshow
Old Jan 15, 2006 | 07:48 AM
deserthonda's Avatar
ORIGINAL: strictly07
what exactly do you mean when you say ( how do i disengage the lock ?? )..
Old Jan 15, 2006 | 11:27 AM
strictly07
ORIGINAL: deserthonda
you are joking right?Thx again for the info
Old Jan 15, 2006 | 07:01 PM
lightshow's Avatar
theres a key hole so that you can disengage the park lock, just in case something happens and the car needs to be moved. ex would be like a dead battery.
lightshow
rydnlow1120
11
Nov 11, 2015 05:29 PM
falkore24
Aug 6, 2008 03:50 PM
plumtreeboy
Mar 13, 2008 12:20 PM
rudegyal
Feb 25, 2008 12:33 AM
thunder_x
Oct 24, 2007 10:26 AM
