Shift solenoid D 2004 accord ex v6
Old Dec 17, 2015 | 06:16 PM
James Chestnut's Avatar
Default Shift solenoid D 2004 accord ex 2.4
Didnt know if anyone knew where shift solenoid D was. 2004 accord Ex. 2.4. Generic code po983 -Shift sol D control ckt hi-
Old Dec 18, 2015 | 08:46 AM
Dr. Drivability's Avatar
P0983 is not a valid code for that year/engine, not showing any evidence of "D" solenoid either, just A,B and C.
Old Dec 21, 2015 | 10:01 PM
Thanks Jeff for the response. That code was from advanced auto code reader. So I short pin 4 and 9 together at dlc and try to get codes from ip. Eng light flashes 7 times, pauses then 7 times, pauses and repeats itself with 7 flashes every time (code 7,77,777,7777?) at the same speed. Trans D light does same thing but with 6 (code 6,66,666,6666?) ABS light same as eng light with 7 flashes every time. Air bag light was the only one different with flashing 6 times slowly and 1 time fast (code 61?) Trans is not shifting properly (harsh shift) is what sole concern is. TIA
Old Dec 22, 2015 | 12:47 AM
The code 70 from the CEL is for an automatic transmission problem. The code 60 from the D4 is closest to a code 60-4 in my shop manual for an open in the circuit for shift solenoid D. Code 60-4 is also p0983 in the shop manual I have for that accord. Since shorting the DLC connector isn't the most precise way to get codes, I'd go with the coe P0983.
That code can from a bad shift solenoid D or the wiring. The shift solenoids are toward the ground on the transmission and towards the driver's tire according to the shop manual. I can't tell exactly how the solenoid is wired, but it looks like a yellow wire goes to it. You may want to look on ebay for a used part to get an idea of what it looks like.
I'd also highly suggest purchasing a shop manual for your car. you can get a pdf of the manual for $22 at automanualsource.com.
j894
May 14, 2024 06:56 PM
AccorDats
Sep 8, 2012 05:58 PM
swingkid50
May 20, 2012 09:29 PM
bo bradley
Oct 3, 2011 07:23 PM
91sihatchback
Oct 26, 2010 10:53 PM
