Shifting problems
Old Jan 18, 2020 | 11:07 PM
Mgambill's Avatar
Default Shifting problems
I got home tonight and couldn't shift into park, reverse, or drive 1 and 2. What could be the cause? I did try the shift lock release next to the shifter with no success. In retrospect, it was sticking a little bit at nuetral when I'd shift into park.
03 accord
Old Jan 18, 2020 | 11:24 PM
Do the brake lights turn on when you press the brake pedal?
Old Jan 19, 2020 | 01:56 AM
Mgambill's Avatar
[QUOTE=PAhonda;389027]Do the brake lights turn on when you press the brake pedal?[/QUOTE
No but the last time i took it in, i was told that id be needing a rear caliper.
Old Jan 19, 2020 | 10:03 AM
The question about the brake lights is because the shifter is interlocked with the brakes. Regardless of needing calipers, the signal from the brake pedal to the lights also tells the shift-lock solenoid to release. But I guess the shift-lock release should have allowed it to shift.
So how about mechanical issues around the shift lever? I'd remove the console panels around there so you can see the shift-lever pivot and look for something mechanical that gets in the way of moving the lever.
Old Jan 19, 2020 | 11:00 AM
Below is a video on how to release the shift lock manually. Just want to make sure you are doing that properly.
Please have someone press the brake pedal and look to see if the rear brake lights turn on. If this is your issue the repair is fairly easy.
Old Jan 19, 2020 | 02:20 PM
Mgambill's Avatar
It was in fact the shifter. I took the cover off and the button wasn't making contact with the plunger. Thank you.for the suggestions.
Old Jan 20, 2020 | 04:48 PM
The Toecutter's Avatar
Cool. Thanks. We like to hear what the problem was in case someone else has the same problem.
Blastingas10
Sep 27, 2015 10:06 PM
Dr. Drivability
Mar 20, 2014 09:48 AM
83Daley
Jul 7, 2009 09:10 PM
foxylady23
Apr 27, 2008 05:30 PM
badxdawgx818
Apr 4, 2008 12:59 PM
