Brake lights won't work and shift control is stuck in park
Old Sep 27, 2015 | 06:49 PM
Blastingas10's Avatar
Default Brake lights won't work and shift control is stuck in park
So that pretty much sums up my problem. My 91 accord automatic hasn't wanted to leave park the last couple days. This is simply taken care of by using the shift lock release, putting it in neutral, starting the car and then shifting to drive. The car runs as good as ever so I assumed it was something to do in the shifter linkage or something. But then i checked the brake lights, they're not working either. So after researching the problem the most common idea is that it is the brake control switch. Which this car has had problems with the brake lights staying on, in the past. Well the problem is, to my knowledge, the brake control switch appears to be fine.
Is that not the culprit? That little white Hershey kiss shaped thing? That presses and releases that black little button? Well as you can see that's there and it appears to be doing its job.
Am I wrong in my indentification of the brake control switch? Are there any fuses I could check? Anyone have any ideas?
Attached Thumbnails Brake lights won't work and shift control is stuck in park-1695jdl.jpg
Old Sep 27, 2015 | 07:32 PM
The brake pedal stopper appears to be installed in the wrong direction.
Brake lights stay on...how I fixed them - Honda-Tech
Old Sep 27, 2015 | 10:06 PM
Well if that is the case it's been that way since I don't know when. Been driving the car for a year now and this is a new problem, with the shifting at least. And it appears to be functioning properly, the button engages and releases in sync with the brake pedal.
rudeg
Dec 31, 2015 07:23 PM
Dr. Drivability
Mar 20, 2014 09:48 AM
natwood68
Feb 24, 2014 12:16 PM
crimedog76
Jan 4, 2012 06:45 PM
malachi_mez
Sep 15, 2010 07:59 PM
