Shuddering/misfire
Old Jun 30, 2010 | 09:37 PM
f1swede's Avatar
Default Shuddering/misfire
Hi! My first post so i hope i dont screw this up. I have -95 Accord EX vtec 4cyl and just replaced distr. cap, rotor and plugs (oem).My questions is i have a shutter or misfire when going thru the gears on light to moderate accelaration i would describe it as water in the distr.cap but it always been dry. It does not happen when i accelarate harder only light to moderate accel. By the way it's automatic. Hopefully someone has some idea were to look. I did search and came close but not completely. Thanks for any input. F1
Old Jun 30, 2010 | 09:57 PM
corvetteking's Avatar
Maybe a bad ignitor/ignition coil... Or bad wires... Any more info on replaced parts???
Old Jul 1, 2010 | 09:12 AM
f1swede's Avatar
thats it as far as new parts. Might run it to the dealer and get a diagnosis. Thanks for your reply
Old Jul 1, 2010 | 02:07 PM
Have the EGR ports been cleaned out?
Old Jul 1, 2010 | 02:11 PM
deserthonda's Avatar
was this issue there before you replaced the parts?? or did you replace parts because of it ??
Old Jul 2, 2010 | 09:39 PM
f1swede's Avatar
the issue was there before i changed parts figuring it would be something simple like that. I will do the EGR cleaning this weekend according to DIY article. I hope that takes care of it if not i will have the dealer look at it. Thanks for getting bck guys. f1swede
Old Jul 2, 2010 | 11:54 PM
kris_loehr's Avatar
I would suggest a cylinder balance test where you eliminate each cylinder under load and see how much each contributes. You brake torque(In gear with foot on brake) the motor up to the RPM that produces the miss and pull the spark plug wires out one at a time and note how much the engine RPM and smoothness changes. No change that cylinder is the miss. You will need a helper, the plastic piers for this task and use reverse instead of drive. If all the cylinders are about the same then you have something global that affects all cylinders such as the EGR.
Old Jul 3, 2010 | 09:40 PM
f1swede's Avatar
3 out of 5 ports were clogged shut completely. Problem fixed thanks guys for all your feedback. f1swede
19Accord97
May 26, 2009 05:19 PM
Illuminator
May 22, 2009 09:39 PM
Lulu EXV6
Oct 24, 2008 11:28 PM
Lulu EXV6
dgem
Feb 15, 2008 12:06 AM
