Simple question - Having a problem getting the alternator to seat
Old Jul 9, 2013 | 05:58 PM
tlhfirelion's Avatar
Default Simple question - Having a problem getting the alternator to seat
I re-installed my 97 accord SE alternator. All the bolts went back in but for the life of me I cannot get the alternator back tight to where the belt doesn't squeak. I've stopped short of using a rubber mallet but any feedback on how I should stand or hold my mouth just right is appreciated. lol
Old Jul 9, 2013 | 06:22 PM
Are you able to turn the adjustment bolt to tighten/loosen the belt?
You must move two bolts and one nut to adjust; loosen the main pivot bolt, loosen the lock nut under alternator to free the adjustment bolt, and turn adjustment bolt to tighten/loosen the belt.
Either something is missing (adjustment bolt and lock nut) or you have not released the alternator to be able to move.
Old Jul 11, 2013 | 09:21 AM
Ok so your advice was accurate, I didn't have the bolts loose enough. I had everything connected and the boots covering the appropriate connections. My wife's hands are smaller then mine and she was tightening the last bolt. I just so happened to be looking at the new battery and fuze box when I heard a pop and the left cable going to the 80A relay/fuse moved. I looked and sure enough it is blown as the cooper wire inside doesn't touch and its all black.
What on earth caused that? It is the original fuse and I did get a larger battery. It's CCA 0degrees F is 675. At 32 degrees F it is 850. Is this too much or did I do something else to cause this?
Old Jul 11, 2013 | 09:22 AM
I verified there is no power going to the car now, no lights or anything.
Old Jul 11, 2013 | 12:14 PM
She tightened the B+ wire to the alternator w/o removing the negtive battery terminal.
Only a tiny brief touch of wrench to ground blew the fuse. You would have noticed a long ground as wrench would have become very hot. It is possible you damaged the battery.
Old Jul 11, 2013 | 02:28 PM
Well crap. I replaced the fuse reconnected the battery. The car started right up 3 times with no issues. Should I take the battery to get it tested? How would I know if anything is damaged? I bought a spared fuse in case it pops again. Hopefully the alternator and new starter were not damaged. Well find out tomorrow when I leave for work!
Old Jul 11, 2013 | 06:36 PM
The fuse should have protected the battery. I would drive and see if any problems appear.
You can buy an Equus Battery Monitor for $16 at walmart that will show voltage which indicates battery health. A good battery should show about 12.2 volts after sitting overnight. If 11-11.6 volts, there may be damage.
Old Jul 12, 2013 | 06:40 AM
I'll pick one up at walmart. Thank you for your help and have a good day.
Johnny Racer
Sep 13, 2012 07:43 PM
MinnesotanHonda
Feb 24, 2010 10:26 PM
Kube
May 31, 2008 10:02 PM
19Accord97
Dec 11, 2006 12:57 AM
ewilson32
Aug 2, 2006 01:06 PM
