slow leak
Old Dec 19, 2008 | 10:41 AM
streetwise's Avatar
Default slow leak
Ive got a slow drip leakat the upper radiator hose clamp, engine side.
My ? is will I lose much coolant if I replace the hose and T stat?
And will I need sealant for the T stat gasket? Should I drain some coolant first?
Old Dec 19, 2008 | 10:46 AM
finch13's Avatar
Default RE: slow leak
You'll have to drain the coolant below the level of the hose first, theres a stopcock on the bottom of the radiator, its white. If the fluid appears to be okay and nice and green, you can put it back in the radiator, if not, replace it.
Shouldnt need to put anything on the gasket either... also, use a Honda t-stat, theyre much more reliable and accurate than the parts stores ones.
Old Dec 19, 2008 | 02:29 PM
The T'stat is not in the engine side fitting on the upper radiator hose. It's on the lower radiator hose, engine side fitting. Usually air intake is removed to access.
florida
Jan 24, 2015 02:42 PM
Johnene
Aug 24, 2010 06:59 AM
v-tec23
Aug 14, 2010 08:43 AM
EBK142
Jul 20, 2009 09:10 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
