Something hanging underneath. Plz Help
Old Feb 12, 2017 | 04:34 PM
Phat's Avatar
Default Something hanging underneath. Plz Help
Something is hanging underneath my 03 V6 accord. Recently had an oil change done, not sure if related. Here is a pic, ill add a video, current one is too large.
Thanks to anyone who takes the time to help..
Old Feb 12, 2017 | 04:44 PM
Looks like the heat shield for the catalytic converter. You can stop by a store like lowes and get hose clamps for a dryer vent and hold that shield in place.
Old Feb 12, 2017 | 04:50 PM
Phat's Avatar
Thanks very much your reply.. if I were to take off and leave it bare, would that be an issue? Or should i jus do a cheap fix
Old Feb 12, 2017 | 05:10 PM
The heat shield blocks heat from the catalytic converter from catching grass on fire. It also protects the converter from rocks and also quick cooling from hitting puddles. The OEM Honda converter is very expensive, so a cheap temporary fix that protects and expensive part is worth it.
I've had that cheap fix on my TSX for around four years and it is still holding the heat shield on there without rattling. I think the clamps ran ~$2 each. Took five minutes to install. Make sure you use jackstands when you get under your car.
Old Feb 13, 2017 | 10:56 AM
I've used large screw-type hose clamps to hold it in place. There's a heatshield above and below the converter, they clamp around it and also protect the floorpan of the car from excessive heat.
All you need to do it clamp the shields around the converter. A couple stainless hose clamps will last for years.
Pajamarama
May 20, 2012 02:20 PM
noboundaries6289
Jul 23, 2007 07:48 PM
96Red240sx
Jan 12, 2007 09:12 PM
Nov 9, 2006 03:27 AM
mojorison_75
Sep 30, 2005 12:38 PM
